need help in identifying
HELLO,
can anyone shed some more light as to what these pistons might be ? known : 94.97 dia piston pin 22mm... 70.92mm long with a 12. 5mm portion milled down to 20mm 1.5mm 1.5mm 4.0mm ring set up 20.93 from top ot piston to top of piston pin mahle 95p31cast inside piston thankx norman http://forums.pelicanparts.com/uploa...1204494528.jpg |
| All times are GMT -8. The time now is 10:06 PM. |
