-   -   1970 911E ignition timing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/396204-1970-911e-ignition-timing.html)
pope 03-03-2008 07:23 AM
OK, it's 30BTDC at 6000rpm. What should it be at idle? Or do I not care?
edit: oops wrong forum....
Mo_Gearhead 03-06-2008 06:33 AM
That is correct (total).
As long as the distributor is advancing in a normal curve, 'initial/idle timing' can be ignored.
wkbergman 03-06-2008 09:37 AM
At idle just a very few degrees BTDC, like 3 to 6
gigem75 03-06-2008 11:54 AM
scratch that thought
