-   -   Which Flywheel is this? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/396221-flywheel.html)
88911coupe 03-03-2008 08:42 AM
I'm trying to absolutely make sure which flywheel I have and I'm a little cofused. The part # is 930-102-233-3R but this does not seem to match anything I can find exactly. Maybe I don't understand Porsche part #s...
How do I know for sure what this is? I can't seem to find an exact match on Pelican. FYI, the starter ring is separate.
tom1394racing 03-03-2008 10:05 AM
Post a picture and we'll figure it out.
The number on the flywheel is the casting/forging number not the final part number.
88911coupe 03-03-2008 10:35 AM
Thanks, I'll try to get a pic...dead digital camera right now. I "think" it may be the turbo flywheel, since I'm pretty sure the PO switched over to the turbo package at the last replacement.
tom1394racing 03-03-2008 04:49 PM
I think you've got a 3.2/G-50 flywheel
911 1986-89
Here's a pic
http://forums.pelicanparts.com/uploa...1204591673.jpg
http://forums.pelicanparts.com/uploa...1204591729.jpg
88911coupe 03-04-2008 08:40 AM
THAT'S IT!
How is that listed on Pelican? Not that I'm replaceing mine since it seems to be in great shape but I'm still curious how I'd know what other parts I need to go along with it.
tom1394racing 03-04-2008 11:54 AM
Here's the link.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_Tclutc_pg3.htm#item9
88911coupe 03-04-2008 12:27 PM
I found that as well...odd that there is no "view in parts diagram" option. Assuming I'm looking at the correct one 911 flywheel 87-89. My car has had the rubber centered clutch replaced with the Turbo version, per the repair bill from Loudens here in Dallas.
