-   -   DC20 Cams With Tbitz MS Setup (http://forums.pelicanparts.com/911-engine-rebuilding-forum/397124-dc20-cams-tbitz-ms-setup.html)
1972_911T 03-08-2008 04:31 AM
Im fitting DC20 cams in my current rebuild 3.0 engine, the engine will be run on common plenum Tbits Efi conversion, am I going to have idle issues with the DC20's on a common plenum? I originally bought these cams as I was intending to run ITB's
JohnJL 03-08-2008 04:56 AM
I ran a DR20 cam with a Carrera alu intake on EFI. I got a broad, fat torque curve though overall peak output wasnt what I had been hoping for.
Car was tracked exclusively. I ran 26lb injectors. The heads needed to be modified slightly to fit the injector angles.
Jeff Alton 03-08-2008 07:32 AM
That cam is designed for a common plenum intake.
Cheers
