-   -   Help with oil switch seal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/397195-help-oil-switch-seal.html)
Dixie 03-08-2008 01:09 PM
Hi all,
Figuring I’ll get quicker answer off the rebuild forum, I'll ask the same question I did in this thread. How do I get the aluminum seal that goes between the case, and the oil switch "stem" off? The seal is glued on with something.
http://forums.pelicanparts.com/uploa...1205010535.jpg
dweymer 03-08-2008 08:27 PM
Should just be a crush washer between the adapter and the case. If it is glued on, try something wooden, like a paint stirrer, and tap it lighty on the side of that. Or a gasket scraper slid between the washer and the case.
