cam timing 911 3.0sc
I rebuild my engine, and I am ineresting if someone can give me same datas about fine timing. I have some datas but it is incompleted, so can someone tell me from the bigining.
The specs are 1.4-1.7 mm for later SC with SC cams, 0.9-1.1 mm for early years.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/347257-80-3-0-cam-timing.html?highlight=cam+timing What year is yours? Lots and lots of threads to look at for the procedure: http://forums.pelicanparts.com/search.php?searchid=1298824 Aurel |
HI peca
you could look hear also, http://forums.pelicanparts.com/911-engine-rebuilding-forum/309382-setting-cam-timing-bolt-snout-cams.html regards mike |
And try this:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/279696-cam-timing.html?highlight=Cam+Timing http://forums.pelicanparts.com/porsche-911-technical-forum/70905-help-cam-timing.html?highlight=Cam+Timing Once it starts to sync you will feel everything move easily. |
| All times are GMT -8. The time now is 11:38 PM. |
