-   -   sand cast AL case full rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/401405-sand-cast-al-case-full-rebuild.html)
ajwans 03-31-2008 05:22 PM
I'm in the teardown phase of a full rebuild of my sandcast 67S engine.
I'd like to know what modifications are recommended in light of 40
years of working knowledge about these engines. I'm going for stock
appearance but don't mind mods where it makes sense.
The things I've settled on so far:
- bigger oil pump from 3 litre engine
- 930 tensioners w/safety collars
- cast iron rocker arms w/bushings
I'm considering getting hotter cams from camgrinder, depends on whether
my camshaft is within spec or not. Also a better distributor from 123ignition.nl
All advice appreciated.
andy
kenikh 03-31-2008 10:35 PM
The '67S charm is the cam. Mess with that and you may alter its appeal. That said, camgrinder made me a set of DC44s on 102 lobe centers. On paper, the are amazing, but won't be running until the end of summer.
ajwans 04-01-2008 04:44 PM
I just got Wayne's book. Brilliant. Lists all the things I need to do to increase
the reliability of the engine. Looks like the 930 tensioners I bought for rebuilding
were actually 901 tensioners like the ones I already have. I guess the safety
collars were worth the $10 I paid.
The experienced guy who is helping me rebuild my engine got me to remove the
rocker arms prior to removing the camshafts, I can't work out why after reading
Wayne's book. Wayne lists the rocker arm removal as one of the final steps.
Any ideas?
andy
tom1394racing 04-01-2008 07:13 PM
Andy
The cams will not come out of the cam towers unless you remove the rockers first.
304065 04-02-2008 08:06 AM
Teardown:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/327369-teardown-1966-901-05-engine.html
Tumble-Polished Case:
http://forums.pelicanparts.com/showthread.php?t=351023&highlight=perfection+defin ed
Rods:
http://forums.pelicanparts.com/showthread.php?t=363493&highlight=think+about+stro king
Pistons:
http://forums.pelicanparts.com/showthread.php?t=368320&highlight=confessions+pist on
Heads:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/348387-bouffant-hairdos-miranda-grace-slick-these-heads.html?highlight=bouffant
Carbs:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/368853-carburatori-bellissimo-restored-weber-ida3c.html?highlight=carburatori
Oil Cooler:
http://forums.pelicanparts.com/showthread.php?t=345812&highlight=pacific+oil+cool er
Measuring things:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/328636-measurement-instruments-metrology.html?highlight=metrology
Sorting out hardware:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/364613-real-cadmium-plating-engine-hardware.html?highlight=cadmium
Assembling Bottom end:
http://forums.pelicanparts.com/showthread.php?t=379187&highlight=assembling+901%2 F05
ajwans 04-07-2008 06:05 PM
Hi John, none of those links work.
andy
304065 04-09-2008 06:47 AM
Linko el-fixo.
