-   -   Mahle Piston Pins (http://forums.pelicanparts.com/911-engine-rebuilding-forum/403045-mahle-piston-pins.html)
lv2race 04-09-2008 10:09 PM
Mahle Piston Pins
Hello,
I have a set of Mahle 81mm Pistons that cam with piston pins that are much heavier than pins I've used in the past. The wall thickness is much larger than other pins I've used. I weighed the pins and found the heavier set weighs 120.9 grams. The pins I have been using weigh 98 grams. I'm using the pistons in a 2-litre racing application. I'm worried the heaver pins will put more stress on the rods. Does anyone have any thoughts or know where I can buy lighweight Mahle pistons pins?
tom1394racing 04-10-2008 02:29 AM
I have a large collection of piston pins.
If you tell me the OD, the length and the wt you need,,,I'll see if I have a set.
lv2race 04-10-2008 07:09 PM
Thanks for the reply Tom.
The dimensions I'm looking for are:
Diameter 0.866 in. 21.996 mm
Length 2.280 in. 57.90 mm
Inside Dia. 0 .469 in. 11.91 mm
Weight ~ 98 grams
Thanks,
Rob
tom1394racing 04-11-2008 02:29 AM
Rob
So you need 22mmX58mm X 98 grams.
I assume you need (6).
Let me see what I have.
I'll send you a PM with a price.
tom1394racing 04-11-2008 03:41 AM
Rob
Check the weight and dimensions of your pins.
I have 22X58mm pins at 92 grams and other 22X58 pins at 102 grams.
I have never seen any 22X58 pins at 98 grams.
