aluminum rods?
Hi all, My Friends 930 engine vomited (rod out the side) he swears the rod is aluminum I don't believe it has anybody seen an aluminum 911 rod? in a street engine. Palmer
Old 03-24-2008, 04:22 PM
Thankfully, I've never seen anyone use aluminum rods in these engines,...
I'm pretty sure that there is no room for such things inside these engine cases.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-24-2008, 05:39 PM
Free minder
Aurel's Avatar
Maybe it was titanium. Ti looks a bit like Al...
Aurel
Old 03-24-2008, 06:45 PM
I have used ally rods in small block chebies -- and boy are they noisy in the morning I have never seen one used in a 911 engine. And like Steve says, thankfully so
Old 03-24-2008, 09:08 PM
I am going go look at the engine tonight I will report back my findings Palmer
Old 03-25-2008, 03:01 PM
I just saw the engine the rods are definitly aluminum. the heads are not off yet so I could only see a stub of a broken rod poking thru the case, The crappy thing about this is the
prevous owner had taken this stock 930 with 140k miles to a well known Porsche
shop south of boston for valve guides and a top end reseal and now 20k miles
this is what he got a 930 bottom end with a knifedged crank and allum rods
and now a window in the block?? my thoughts are he got screwed now he needs a case
rods and one piston and cylinder or another engine. Palmer
Old 03-25-2008, 05:10 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
I ended up with a set in trade of 5 aluminum rods of unidentifiable manufacture. You can guess why I only got 5. 5 desk paperweights is plenty.
Scott Kinder
kindersport @ gmail.com
Old 03-25-2008, 06:42 PM
cfc cfc is offline
Alunimum rod
There has been alunimum rods for sale for 911 engines for 20 years at least.
Old 03-25-2008, 07:59 PM
I'm not an expert on metals but I believe one property of aluminum is that it fatigues when it flexes. Steel and other metals have virtually no fatigue when flexed below bending. Aluminum fatigues no matter how little it flexes. This is why aircraft have a finite lifespan. This characteristic makes aluminum unsuitable for applications like connecting rods.
-Andy
Old 03-25-2008, 10:05 PM
All metals have a fatigue life. Aluminum happens to have a shorter life than other materials. Designers attempt to compensate for this shortcoming by designing the con rod with larger cross sections and beefier construction. In some race applications, less reciprocating weight is a higher priority than durability.
Sherwood
Old 03-25-2008, 10:37 PM
Evolved
Mo_Gearhead's Avatar
QUOTE: "This characteristic makes aluminum unsuitable for applications like connecting rods. "
_________________________
You must be joking?
If you do not know an answer to a technical subject ...please, do NOT just post your 'wild-azz' assumptions.
Don't fear the reaper.
Old 03-26-2008, 07:04 AM
Steel components can be designed for infinite fatigue life based on the stress levels and cycling properties (fully reversed stress, etc...). If a steel part can sustain 1 million cycles without failure in its designed application it will generally last forever. Aluminum can't.
There is no benefit to using aluminum rods over steel because they are such highly stressed parts anyways. The strength to weight of aluminum and steel are the same so to meet the strength requirements with an aluminum rod it would end up weighing the same as a steel rod.
Titanium has a much better strength to weight ratio than aluminum or steel so you can meet the strength requirements and have a lighter part. Ti is very fatigue sensitive however, which is why they are usually reserved for race applications and replaced on given intervals.
Old 03-26-2008, 01:09 PM
3 restos WIP = psycho
kenikh's Avatar
Except in cars like the Honda S2000 and GT3; they are supposed to have an undefined service life. I am not arguing the fact that Ti fatigues...it does. But over-engineering can take fatigue out of the equation by building the rod beyond an expected service life.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-26-2008, 03:29 PM
jmz jmz is online now
jmz's Avatar
someone around here did it years ago. ran good with the lightweight rods right until it didn't run anymore...
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 03-26-2008, 04:44 PM
You must be joking?
Actually that quote came from Bruce Anderson's 911 performance handbook. It is not just a guess but an opinion. Just because you don't like my answer doesn't make it a joke.
-Andy
Old 03-26-2008, 04:46 PM
YTNUKLR's Avatar
Coatings allow Ti service life to be much extended. The issue with Ti is not so much a direct result of fatigue, as galling. Galling is when the surface of the metal is compromised, and it leads to surface risers and eventually cracks. To stop galling Ti, they have surface coatings to minimize the potential for surface risers to even develop-
Scott Kinder
Old 03-26-2008, 05:01 PM
Evolved
QUOTE: "Actually that quote came from Bruce Anderson's 911 performance handbook. It is not just a guess but an opinion."
Opinion ? Whose? His or yours?
With all due respect to you and Mr. Anderson. There are LOTS of engines that have been built/raced with aluminum connecting rods. I (and my friends) have built some myself. To say that "aluminum is unsuitable for use in connecting rods" is an ignorant statement. Thus my comment. Some people come to these boards to learn something.
Perhaps the misunderstanding on my part was that your generic statement seemed to apply to "all engines"...when (in your or Mr Anderson's mind) you/he meant "Porsche engines"???
Old 03-26-2008, 05:17 PM
930gt-40r's Avatar
The top fuelers use aluminum rods to ubsorb the impact of combustion, but they only get used once. I guess on the street where the have to see accel/decell they may get "stretched" faster?
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-26-2008, 05:45 PM
jmz's Avatar
Old 03-26-2008, 06:02 PM
Yes, aluminum rods have been done before for a 911 (CMW sold them years ago) and even for aircooled VWs, even in a configuration of an aluminum rod with a steel cap (yikes!). The guys I work with on the billet steel rods have been making aluminum rods for decades, but have never chosen to do any for Porsche because in their opinion, it's not needed and too much of a liability. In some applications, a steel rod is too rigid and will snap the crank. They use an aluminum rod as a shock absorber, and treat it like a service item. Some engines get new rods every few passes, some every few hundred passes. Some have even run them on the street, but they recommend against that. Aluminum rods are disposible parts and must be replaced often, since a failure is pretty catastrophic! Ti is the way to go if you need light rods for a Porsche, as the factory did :-)
If you feel like learning more about aluminum rods, check R&R Racing Products out - http://www.rrconnectingrods.com
I won't claim to know everything about their rods, but I have been around them long enough by osmosis I have learned quite a bit about both aluminum and steel rods :-)
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 03-27-2008, 06:52 AM
