-   -   need ask some thing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/405672-need-ask-some-thing.html)
lowell 04-24-2008 12:31 AM
need ask some thing
Hey, my Porsche carrera C4S 03, got some miss fire, so the oil goes into the ignition coil and this thing has been burned.
I need to replace 4 ignition coil pack.
Does anyone know how much does the Ignition Coil pack cost from Original Porsche?
I seems like being raped off from my dealer. He asked for 375 for each Ignition Coil pack and 20 dollars from Labour. Im lives in vancouver, b.c, Canada.
Thx
BoxxerSix 04-24-2008 05:24 AM
No idea what the dealer charges for 2003 coilpacks but Pelican sells them for $62 each
Steve@Rennsport 04-24-2008 10:48 AM
Your 996 C4S uses coil-on-plugs and there are six of them, naturally.
$62/each is about right.
Fast Corners 05-07-2008 12:23 PM
If the coil pack was destroyed by oil seeping past the seals you will also want to have the seals replaced on both ends of the tube that the spark plug and coil pack connector fit inside of.
Replacing those seals will be more than $20 of Labor.
