1973 2.4L 911T Pistons/Rings/Wrist Pins
I need to purchase 6 pistons for a rebuild
Who would you recommend that I purchase these pistons from?
I am looking for a reputable manufacturer and/or distributor
Old 04-21-2008, 07:10 AM
The first question I'd ask is what condition are your cylinders in?
Any bore taper wear?
There are several piston options including Mahle (dealer only), JE, CP and some others. If you use a JE or CP, its very critical to ensure they fit properly otherwise the engine will be noisy when cold and the rings won't last long.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-21-2008, 08:22 AM
Roger 911's Avatar
Weren't the pistons different between the MFI and CIS engines as well?
Old 04-28-2008, 09:56 AM
