converting a sportomatic to stick
a couple of questions on the process. Is there a tube in the tunnel for the clutch cabel, are the half shaft axels the same length
thanks, hushpuppy |
HI hushpuppy
the cable tube should be in the car , I have the parts list you may need the change the car over to manual for you, I do not think the shafts require changing, but it could depend on the year and box change, http://forums.pelicanparts.com/uploa...1209137489.jpg regards mike |
| All times are GMT -8. The time now is 06:38 PM. |
