mca, remarkably my layshaft gear looked almost new, but I'm planning on replacing the chain gears because the gear teeth looked worn. I'm waiting to hear back from the machine shop, hopefully by then I can get a good idea of the parts I need to replace... What about you?
I am nearing my budget for this rebuild but I don't want to skimp on items ... especially those that are inside of the case. The opinion on replacing those gears seams to be 50/50. |
Parts Update
Hello all, here are some updated pic's of my parts back from getting powder coated and blasted.. :D
http://forums.pelicanparts.com/uploa...1211241294.jpg http://forums.pelicanparts.com/uploa...1211241327.jpg http://forums.pelicanparts.com/uploa...1211241347.jpg http://forums.pelicanparts.com/uploa...1211241362.jpg http://forums.pelicanparts.com/uploa...1211241384.jpg http://forums.pelicanparts.com/uploa...1211241451.jpg http://forums.pelicanparts.com/uploa...1211241474.jpg http://forums.pelicanparts.com/uploa...1211241493.jpg http://forums.pelicanparts.com/uploa...1211241511.jpg |
Very nice! If I were you, I would sand the top of the Porsche letters on your valve covers to make them stick out more.
Aurel |
Thanks, that's a good idea..
SSI & Oil Lines
Do the TWO new oil lines required for the SSI conversion/installation replace the big metal oil line that is attached to the engine which connects to the hard oil line on the car/thermostat? I want to replace them both, but I'm not sure if I need to after buying new SSI heat exchanger's and the required lines for them, are these lines the same? :confused:
Here are the part numbers for the new oil lines 911-107-739-10-M20 911-107-728-00-M20 |
I just did the SSI / Weber conversion on my 81 sc. You only need to replace the one line. Block to thermostat. Actually, it is 2 lines, one steel and one rubber. It reverts back to the line used on the two seven. Pelican has two listings for the line. One has the front trombone type oil coller in the front fender well, the other doesnt. It should be simple to select the right lines for your needs. Cheers If your going Carbs, I strongly suggest an MSD igniton system. |
ok, I purchased those lines already so I guess I should be good to go.. Thanks!
Engine back..Time to Rebuild!!
The fun begins! I got my engine back from Ollie's, so now it's time to rebuild. Ollie's did an Excellent job! they explained in detail what had to be done and answered all of my questions in great detail. All my parts look fantastic! I recommend them 100%.
Step 1. Crank assembly with stock Rod's using RaceWare Fasteners. http://forums.pelicanparts.com/uploa...1215193300.jpg http://forums.pelicanparts.com/uploa...1215193432.jpg http://forums.pelicanparts.com/uploa...1215193446.jpg http://forums.pelicanparts.com/uploa...1215193463.jpg http://forums.pelicanparts.com/uploa...1215193477.jpg http://forums.pelicanparts.com/uploa...1215193492.jpg http://forums.pelicanparts.com/uploa...1215193566.jpg http://forums.pelicanparts.com/uploa...1215193631.jpg http://forums.pelicanparts.com/uploa...1215193648.jpg Using a ARP Rod Bolt Stretch Gage, I was able to determine stretch and clamp load. I installed the fasteners lightly oiled with Loctite 243 for added insurance. RaceWare indicates by using the stretch method while installing their fasteners adequate stretch ranges from (0110 to 0115). I found being in the middle, (0112 to 0113) worked the best fro me. All the Rods turn freely, smooth and without any sticky spots or hang ups. http://forums.pelicanparts.com/uploa...1215193943.jpg I'll be starting on the case soon, I feel it's still not clean enough! |
Update...
Hi everyone! Finally I can update my thread a little. I received my replacement rod and started the rebuild again. The pictures I previously posted of my crankshaft and installed rods had to to be disassembled due to a miss printed label on the raceware packaging. The rod fasteners were actually for a 3.2 liter engine and not a 3.0... I tried to obtain the new bolts as quickly as i could, no luck back ordered everywhere. I then decided to use ARP instead. I reassembled the rods on the crank, everything was going smoothly until my last rod. The big ends on ARP rod bolts spun out in the rod cap causing damage to the cap and fastener. At first i was told it could have been a manufactures defect with the rod bolts, but they check out to be in specification. The rod was the culprit! The person who I sent the rod out to stated to me that in the 20 + years working on Porsche engines has never come across this situation. I guess everything happens for a reason, who knows what could of happen to my engine if this bad rod wasn't discovered. :eek:
Bad Rod... http://forums.pelicanparts.com/uploa...1222239526.jpg Here are a few pictures of my progress... http://forums.pelicanparts.com/uploa...1222239385.jpg http://forums.pelicanparts.com/uploa...1222239429.jpg http://forums.pelicanparts.com/uploa...1222239452.jpg http://forums.pelicanparts.com/uploa...1222239497.jpg http://forums.pelicanparts.com/uploa...1222239620.jpg http://forums.pelicanparts.com/uploa...1222239643.jpg http://forums.pelicanparts.com/uploa...1222239678.jpg http://forums.pelicanparts.com/uploa...1222239690.jpg |
Some more pictures
http://forums.pelicanparts.com/uploa...1222239837.jpg
New thermostat with Elephant Racing lines http://forums.pelicanparts.com/uploa...1222239859.jpg New updated oil cooler http://forums.pelicanparts.com/uploa...1222239913.jpg http://forums.pelicanparts.com/uploa...1222239959.jpg http://forums.pelicanparts.com/uploa...1222239982.jpg http://forums.pelicanparts.com/uploa...1222240006.jpg http://forums.pelicanparts.com/uploa...1222240031.jpg http://forums.pelicanparts.com/uploa...1222240167.jpg http://forums.pelicanparts.com/uploa...1222240191.jpg http://forums.pelicanparts.com/uploa...1222240230.jpg At this point I'm beginning to pre-assemble the engine to check the valve to piston clearances. |
Sabeo,
Where did you get those cool temporary cylinder retaining nuts? Thanks, Mark |
Sabeo,
Nice work! Looks great. You are making nice progress. I also have the finned oil lines and the cooler in the fender. Did you install a fan behind it? I am guessing you didn't b/c I still see the horn. Keep up the good work. Cheers, Craig |
I can assure you that those oil lines won't dissapoint you!:)
I did the same thing, and they work a lot better than the original ones... |
Also, it looks like the purge valve may be leaking. I can not say for certain until I inestigate it more closely this weekend, but the area around the valve is wet. Elephant suggested that I used too much force when installing the lines. I will admit, they were a tight fit but I didn't have to hang on them with all of my weight or anything. The finned lines are larger than OEM and there isn't much wiggle room with the OEM lines either. Anyhow, a little bothered by it ... but I suppose it isn't a huge deal. |
You got any more updates or what? Want more pics!!!! |
| All times are GMT -8. The time now is 10:49 PM. |
