Exhaust stud removal
Hi!
![]() I'm new here, and I have decided to enter here because of all the expertise I see. Here in Norway, we have tech-forums for Porsche, (Porsche-club-norge.no), but Norway is a small country, so answers to questions may be limited. I am currently doing a rebuild of my '79 911 SC. I have removed the heads, with the exhaust studs still in there. Some are broken off, with apx. 5 mm sticking out. My question is this: Is it wise to try to remove these studs now that the heads are off? I am worried this will bend the heads if I put them in a vise, and start applying force to the studs... Perhaps it is best I leave this to the shop, since they will refurbish them anyhow? (It's just that I am trying to save a few bucks, and labour ain't cheap, unless you do it yourself..) ![]() Best regards, Otto |
Free minder
Otto,
If you are sending the heads to be rebuilt in a shop, let them take care of the studs. The cost was minimal in the whole bill , ask them how much they charge per stud. If you want to try yourself, spray some penetrating oil, use a propane torch, and use the tool I posted in my thread. But the saving isn`t worth the effort, in my opinion. Aurel |
I just had my heads redone her for a valve job and the shop charged me a minimal amount to remove/repair the studs. You may just want to call the shop to check but in my case it was next to nothing to have the work done. Something like under $10 so is was not really much of a hard decision. Of course by taking the engine out and disassembling it myself I am saving a fortune.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten Last edited by 88911coupe; 05-05-2008 at 07:48 PM.. Reason: clarity |
Thanks guys!
That's what I wanted to hear... Probably better to let the professionals do this, since I would have used a lot of time trying to remove them... -Espescially if the cost is reasonable! |
+1 on the advice to let the machine shop do the stud removal. Shop charged me $10 per stud and that included installing a helicoil in each hole.
Mike...
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold |
