-   -   ARP Head Studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/409179-arp-head-studs.html)
retrotech 05-13-2008 07:35 PM
ARP Head Studs
Any pro's or con's to using the ARP head studs on a 2.8?
YTNUKLR 05-13-2008 08:09 PM
pros=they are better than dilivar, better than stock steel, better than 993TT in holding strength, less expensive than 993tt studs
cons=they loosen more than any other head studs i've tried, not as good as supertec head studs
kenikh 05-13-2008 09:51 PM
Another vote for Henry, then. Scott, if you had a spare set of used stock steel head studs lying around, would you spend the money on the Supertec units?
YTNUKLR 05-13-2008 11:25 PM
it depends what you're building, i think. i try not to tell people what to do with their engines, only what not to do, because i don't want somebody to say, "hey , i would have used ____ studs until i got scott's advice...now i gotta take apart my motor to fix a broken steel stud..."
i will say that i have never seen a broken steel stud, steel studs were/are used in all kinds of hot engines, and i even used them in the 906-spec. 2.0L i put in the infamous "Adamowicz" machine [SEE this month's Excellence!]
YTNUKLR 05-14-2008 06:25 PM
http://forums.pelicanparts.com/uploa...1210814591.jpg
Eagledriver 05-14-2008 08:39 PM
If you are using a Mag case then I'd use Dilivar studs. I'm in the minority here but I've seen steel studs (like ARP) pull even with timecerts.
-Andy
retrotech 05-14-2008 08:50 PM
Thanks for all of the feed back. The ARP's have been shipped, so that is what I will go with. What started this, was my engine was reassembled after rebuild, to the heads. When the builder returned to the shop, the next moring, there was a broken head stud on the floor. A stud snapped while sitting there?! He is a well known, well respected mechanic in the NW. They were torqued to factory specs. So I got all freaked out about steel, and bought the ARP's
Has anyone ever heard of this happening before?
Eagledriver 05-15-2008 08:22 PM
That was most likely a Dilivar stud. Was it old or new? Some break when new but rarely. The rash of broken studs we are now seeing in SC and Carrera engines are on engines that are 20-30 years old.
-Andy
retrotech 05-15-2008 08:33 PM
I have no idea how old the studs are, but the engine was built about 10 years ago, and had 14 - 18,000 miles.
911pcars 05-15-2008 11:37 PM
This might be one of the first recorded cases of steel stud decapitation. Real Dilivar studs are non-magnetic. Can you apply the magnet test to the broken stud and let us know?
thanks,
Sherwood
