Ambitious Outsider
sabeo.m's Avatar
Unhappy Timing Chain Housing's
HI guy's I think I made a mistake; I had my Timing chain housing's sandblasted and not bead blasted as was instructed by WD rebuild book! I know I have to clean them like there's no tomorrow to get the sand residue off, but did I potentially mess up the matting surface's on the housing's? Did I destroy them?
1988 3.2 Cab
2005 997.1 C2S
Old 05-16-2008, 08:03 AM
dtw dtw is offline
GAFB
Mating surfaces should be fine as long as they are not pitted from blasting. You can go over them with some scotchbrite if you like, to smooth them up. This is also a good opportunity to make sure your mating surfaces are still flat!
Several BMWs
Old 05-16-2008, 08:40 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I would use a straight knife blade set at 90 degrees to the surface and scrape them gently. This removes pitting and corrosion. It should leave a nice shiny surface behind. I did this a couple of times on 3.6 engines when re-sealing cam housings and there were leak-free every time.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-16-2008, 02:22 PM
Ambitious Outsider
sabeo.m's Avatar
Awesome! Thanks guy's!!
1988 3.2 Cab
2005 997.1 C2S
Old 05-16-2008, 03:09 PM
