Forced Induction Junkie
WERK I's Avatar
C2 Cylinders/Head Seepage
Do any of you remember the problems with some of the C2 cylinders/heads seeping oil? I know there were only a small percentage of engines with the problem but I was wondering if any of you recall how it happened. Was the the heads, the cylinders?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-14-2008, 05:39 AM
resident samsquamch
sand_man's Avatar
The only thing I can remember was that (I *THINK*) a special gasket/o-ring needed to be used with the cylinders.
-jeff
Old 05-14-2008, 06:15 AM
MBruns for President
JeremyD's Avatar
Heads to cylinders - Porsche bulliten states that if the area is wet to the touch - they need to be addressed.
The solution is new P & C's - although I think that Ollies is now machining in a later sealing groove.
Old 05-14-2008, 07:01 AM
Dave,
The leakage was due to lack of sealing rings between the heads and cylinders. Late, replacement cylinders had a groove for a gasket and the heads can be machined to suit.
We've had really good luck machining those early heads for a sealing ring and them modifying the tops of the existing cylinders to fit. After 20+ sets over the past 6-7 years, nary a leak.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-14-2008, 09:51 AM
Jeff Alton's Avatar
I had one of those sets Steve speaks of, working great!
Cheers
www.turn3autosport.com
Old 05-14-2008, 09:59 AM
Originally Posted by Steve@Rennsport View Post
Dave,
Steve, if it isn't giving away some proprietary situation, I am intrigued how after surfacing the heads out to the later barrel specs you can reuse the barrels.
I respect that kind of ingenuity. Once again if you don't mind a picture would be cool.
Old 05-15-2008, 07:14 AM
I don't have any pictures but we machine the heads for the later sealing rings and put a small bevel on the top edges of the cylinders to exert pressure on the rings.
Works great.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 05-15-2008, 07:26 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I run a set of "early" C2 barrels machined by Walt from Competition Engineering. They were a warrantly replacement. He machined a step into the top sealing surface and I put a fire-ring in from the Turbo. The engine is leak-free for 20.000 miles now and I am very happy with that. Mine were leaking a lot before and were unsalvageable. They went out of round.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-16-2008, 01:08 PM
