-   -   What are "Eschuchie" pistons? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/409238-what-eschuchie-pistons.html)
304065 05-14-2008 08:27 AM
I have heard of these recently. What do we know about them? Photo?
911pcars 05-14-2008 03:28 PM
"What are "Eschuchie" pistons?"
Are you sure it's not "escutcheon pin"? (basically a brass nail or brad with a round head).
Sherwood
Aurel 05-14-2008 04:45 PM
Those are worn out of specs pistons from a mismatched set, installed by hispanic illegals hired $10/h by Motormeister :D.
Aurel
cnavarro 05-14-2008 04:49 PM
Maybe it's Eskuche, as in Ecurie Engineering, Inc.?
304065 05-15-2008 06:08 AM
Hmm. . . here it is used with incorrect spelling
http://forums.pelicanparts.com/porsche-914-used-parts-sale-wanted/404035-e-production-2-0-six-race-engine-hsr-scca.html
Escukie is the correct spelling, as in Mark Escukie, from Ecurie Engineering.
Now that the word is right, anyone have any details on the pistons?
ErVikingo 05-15-2008 06:24 AM
Hey John,
Its Mark Eskuche (pronounced Escookie). He has his own piston design for race engines.
Cheers, Juan
304065 05-15-2008 06:42 AM
Thank heaven that is cleared up. For a minute I thought somebody was talking about écureuil (Only Dr. Du Pasquier will get that joke probably)
Now what makes these special?
euro911sc 05-15-2008 10:22 AM
I've been over to Mark's FL shop a few times. Nice fellow doing some great vintage work. He summers in WI at his second shop I believe. Don't know anything about the pistons, just the man.
Best regards,
Michael
xtremech 05-21-2008 06:28 PM
We have done and continue to do buisness with Mark @ Ecurie. I can tell you from experience that his pistons and other products that he has developed and marketed are top quality. I know many engine builders that use his 356 as well as 2.0ltr design piston.
I am sure he would answer any questions on this matter if contacted directly.
Regards, Bill D
Henry Schmidt 05-22-2008 03:11 PM
From memory and my memory is fading fast :)
The sets of Mark's pistons I've seen are very high compression JE pistons with small valve pockets. The heads ran small valves (specially lightened) and very conservative ports.
If I remember correctly the cams were somewhat conservative as well.
xtremech 05-23-2008 12:38 PM
Henry, your memory is still good. Marks pistons are generally geared toward high compression.
He does build a conservative but reliable engine.
