-   -   Fan Housing – Alternator question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/410984-fan-housing-alternator-question.html)
ken180 05-23-2008 11:16 PM
Hi All,
I have two 911 Fan housings both marked 901 106 101 5R.
They are different in that one has a deeper seat for the Alternator.
The alternators are of a different thickness to allow for this difference.
One setup is from a 914-6 (911T) but I am not sure what engine the other one is from.
I have never seen a part with the same number be different. Can someone explain the difference??
Thanks,
Ken
dtw 05-24-2008 10:16 AM
B/c it isn't a part number - it is a casting number. The deeper recess will be a later housing w/bigger alt - can't remember the specs off top of my head. I'm sure someone will, though.
ken180 05-24-2008 12:37 PM
Casting # or P/N, still seems odd they would be different.
Ken
ken180 05-24-2008 02:40 PM
Googled the Marchal alternators.
The short alternator that fits the shallow casting is a 55 Amp unit.
The long alternator that fits the deeper casting is a 70 Amp unit.
Ken
Walt Fricke 05-24-2008 10:38 PM
Ken
When you think it through, I think you may not think it quite so odd that the casting numbers stay the same until the casting itself needs to be changed. At that point new molds are in order. But until then, use the old masters. Since the parts are machined anyway, it is easy just to change the machining - as in this case.
Heads and cam carriers are other prominent examples (though the heads get a casting date, so they could make other changes where Porsche thought it worth while.
Walt Fricke
304065 05-25-2008 03:42 AM
Ken, interesting find!
Usually you have to get a 930 (911SC) casting number shroud WITH coil studs to fit the long one. Perhaps one of yours has been machined?
