bavaria911's Avatar
Rubber fuel line to Bosch fuel pump
I have a 1971 Targa 911T and had the Bosch fuerlpump rebuilt and now started to install the part. The rubber line after the tunnel from the fuel tank is a little larger than the return line to the tank. I need to replace both of the 44 yr old lines. What are the sizes? I noticed the one from the tank is larger , based on the nipple size on the bosch fuel pump.
Can someone confirm the size of both?
Vr,
Scott
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 02-15-2015, 08:16 PM
Das Schnell Ei's Avatar
I have a later car (75-77) and the feed line is 11.5mm ID ...return is 9.5mm ID
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 02-16-2015, 05:57 PM
