Insane Dutchman
Turbo vs Carrera Oil Pump Porn
Well, for absolutely no good reason I found and bought a brand new Turbo oil pump to go into my 3.4 project. For background, I am in parts assembly mode now, have a brand new case, Mahle 98mm P/C with 10.3 compression, Carillo rods, '79 heads done by the fine Dr. Weiner.....the rest is still to be collected, things like Coil on Plug, EMS, "S" cams etc.
Anyway, just for your viewing pleasure, here is my brand new Turbo pump beside my brand new Carrera pump. Turbo is a lot bigger and a lot heavier too. I know from my reading that in theory only the scavenge side of the Turbo is bigger, but it sure looks like the pressure side is bigger too...
Only real question is whether I disassemble the pump as per the recommendations on this board, it is apparently 10 years old and been sitting in a box for that time. It is pretty stiff to turn by hand, much stiffer than the equally new Carrera pump.
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 06-14-2008, 09:27 AM
PRO Motorsports
Tyson Schmidt's Avatar
It's stiffer because the cosmoline has dried.
I installed a set of NOS 2.7 RS pistons and cylinders once, and they had been sitting on the shelf so long that the cosmoline had basically glued the piston inside the cylinder. I had to soak it in brake clean and warm it up with a heat gun to remove each piston.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-14-2008, 07:29 PM
3 restos WIP = psycho
kenikh's Avatar
I did the same thing...had a 3.2 pump then came across a Supertec prepped 930 pump. Good stuff!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-15-2008, 09:32 PM
304065's Avatar
Sometimes the best things happen "for no good reason."
I would absolutely take the pump apart, it's easy, just make sure you note the orientation of all the pieces so you can get it back together exactly. I bet you will be surprised with what you find inside.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-16-2008, 08:29 AM
911 tweaks's Avatar
if you do take the pump apart, please post pics for the ever curious "tweakster"!!
Thanks, Bob
I live for 911 tweaks...
Old 06-16-2008, 09:21 AM
