Broken intake stud.
Greetings
I purchased a pre 1980 3.0 with one broken intake stud with a bad repair job and the rest of the intake studs refuse to come out.
I have a few questions.
1) can a machine shop repair the poor repair job by installing an insert or welding the head?
2) the rest of the studs will not come out. Does anyone have any suggestions for this problem?
Thanks!
Old 06-10-2008, 07:27 PM
abit off center
cgarr's Avatar
Anything can be fixed, I have made my own inserts for the exhaust to fix some butchered jobs before so a good shop should be able to fix it if they really want to.. Heat has always worked for me on stubborn studs.
______________________
Craig
G2Performance
Old 06-10-2008, 08:20 PM
Well thats piece of mind for me - thanks.
do you heat the stud or heat the head?
Cheers
Old 06-10-2008, 08:28 PM
ael911's Avatar
When I did my PMO conversion, I broke one stud due to not using the torch. Luckily, there was still enough thread left to whack on a stud puller. I soaked each stud with a good penetrant for a couple of days. Then I used mapp gas on the surface around the stud, not on the stud, for approximatley a minute and half. Then turn the double nut and all studs came out without any issues.
'75 911S Silver Anniversary #164(Formerly JTO's)
Rebuilt 2.7 with full ARP, 9:1 CR.
SSI, GHL, ER polybronze bushings, finned oil lines.
Lowered and corner balanced. CIS retired, now PMOs!
'65 912 slate gray sunroof (driving project)
Old 06-11-2008, 07:56 AM
I heated the studs with propane and got all but one. The last one I welded a nut onto and the heat from the welding helped to break it loose.
-Andy
Old 06-11-2008, 09:19 AM
