oil pressure relief pistons
I'm having difficulty getting the oil pressure piston removed from my 2.7 engine. Any advice?
Thanks in advance,
Jason
Old 06-05-2008, 03:57 PM
aws aws is offline
I sometimes will use a tap to reach down in the oil pressure relief hole and break the piston loose if it is frozen up. You will usually ruin the piston if you use this method. You have be very careful you do not scar the passage hole with the tap when doing this. Make sure you have lubricant in the hole after you get the tap seated in the piston, twisting the tap to break the piston loose, then try to work the piston and tap out of the hole by twisting in a tightening direction and pulling on it. Good luck.
aws
Old 06-05-2008, 10:32 PM
BTDT....a hardwood dowel or square that fits into the passage, carved down to a taper to slightly larger than the ID of the piston. Tap gentley into the piston. Withdraw....mine came out.
JPIII
Early Boxster
Old 06-06-2008, 08:19 AM
"farking Porsche hero"
Rich Lambert's Avatar
Did you try a magnet on a stick?
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 06-06-2008, 09:44 AM
OldTee's Avatar
X2 Use a gentle pull. Oil his holding it up.
Old Tee
all 911s sold
Old 06-06-2008, 02:58 PM
