-   -   Perfectbore cylinders: No Gasket? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/413677-perfectbore-cylinders-no-gasket.html)
JohnJL 06-08-2008 07:18 PM
I am assembling a set of new Perfect Bore 3.2 cylinders with my 3.0 heads that have been machined flat at the perimeter and "dished" a bit and twin-plugged. THe shop that does this is well known for their custom machine work and they had both the cylinders and heads (and pistons) to mock everything up before assembly.
I noticed there are no grooves in the Perfectbore cylinders.
http://forums.pelicanparts.com/uploa...1212977828.jpg
Is it acceptable to assemble them without any head gasket/sealing ring? All the engines I've done before used a sealing ring...
Not much info on the Perfect Bore website...
kenikh 06-08-2008 07:44 PM
Yep, pretty standard stuff. My 2.3 w/ Nickies is the same way. You'll notice Porsche ditched the CE rings on the 964, as well.
JohnJL 06-08-2008 07:54 PM
Thanks Kenik.
