polizei's Avatar
Reusing Mahle Pistons
Hello,
I recently picked up a set of 3.3L Mahle cylinders with 8.0:1 compression pistons from Road & Race. I found out after purchasing them that the cylinders were machined for flame ring. I'd rather not send my heads out to get machined for flame ring as well, so I am wondering if it is viable to keep my pistons and just get another set of 3.3L cylinders. The cylinders & pistons are in spec for a rebuild (otherwise I wouldn't have purchased them, obviously). If it is OK to swap the cylinders, should I re-ring? Thanks for your help guys.
Andy - 1987 911 Carrera Coupe
Old 06-11-2008, 01:49 PM
polizei's Avatar
Bump. Any thoughts?
Old 06-12-2008, 08:17 AM
3 restos WIP = psycho
kenikh's Avatar
If the pistons and ring grooves are in spec, you can re-ring and reuse in new cylinders, no problem.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-12-2008, 08:37 AM
