-   -   Cam timing. The most allowable advance and retard? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/414499-cam-timing-most-allowable-advance-retard.html)
Noah Holcomb 06-13-2008 09:10 AM
On a ROW 3.0 with the stock Nikasil 8.5:1 pistons and SC cam what is the most degrees the cam timing can be retarded and the most that it can be advanced before the engine starts to experience piston to valve clearance problems?
TimT 06-13-2008 12:10 PM
You would have to measure the clearance at the extremes, i.e. set the cam timing further advanced, or retarded, then measure piston clearance through an engine cycle.
Ive set cam outside the "spec" but have checked the clearance, and have a dyno to see the results in real time.
Eagledriver 06-13-2008 07:01 PM
These cams had a spec of .9mm to 1.6mm depending on the year motor. So you can safely say they will work in that range. I doubt there would be a performace advantage to going outside that range. If you want to go outside that range just measure the clearance during assembly.
-Andy
dtw 06-13-2008 09:19 PM
Was just talking to a well-known builder about this very subject. Said his shop regularly timed stock 3.0 motors to 1.5mm for optimum performance. Maybe he'll weigh in here...
