-   -   Carrera vs Turbo chain tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/415242-carrera-vs-turbo-chain-tensioners.html)
Henry Schmidt 01-26-2009 09:48 AM
Originally Posted by ajwans (Post 4048901)
How do you attach that spacer to the idler arm? Is it a big bushing turned down on the idler
end and pressed into the arm?
andy
Sorry for the delay in responding. The idler arm is machined out to accept the new bushing.
http://forums.pelicanparts.com/uploa...1232992408.jpg
http://forums.pelicanparts.com/uploa...1232991858.jpg
cgarr 01-26-2009 10:41 AM
Henry, Have you ever tried an internal collapse stop inside that tensioner rather than the collars?
Henry Schmidt 01-26-2009 10:54 AM
No, but the idea sounds good.
My only concern would be: Why would I want to disassemble a new tensioner to install a stop when a collar can be added without disassembly?
