Crank shaft work
Anyone know of good place to have a crank worked on the the Cleveland, Ohio area?
Rick
1985 911 Targa RarlyL8 center outlet muffler & waste gate dump,GT30R turbo,.9 bar spring,Canems programable DME, around 400 wheel hp SOLD BUT NO FORGOTTEN
Old 06-21-2008, 03:13 PM
You might try Gellner Engineering on Bookpark Road. They will balance, polish, magnaflux and a few other or perhaps give you a lead if you need more.
Old 06-23-2008, 03:40 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Before you send the crank anywhere...."ring" it first.
Hold it by one of the counterweights, strike it CAREFULLY with a wrench or something metal.
Listen to the sound it makes.
If it sounds clear like a bell.....no cracks (probably).
If it goes "doink"....you got problems.
You might have to get it welded....and that is not the best solution for our engines....means a lot of expensive work.
Bob
Bob Hutson
Old 06-23-2008, 06:40 AM
Thanks for the info gentleman
Rick
Old 06-23-2008, 07:33 AM
