teveo's Avatar
Carb primer, anyone?
Hi, I am tuning my 914/6's hot 2.7 engine, it has webers and I am trying to find some good articles on setting them.
It is a rocket from 25% to wide open throttle, but the lowrange it splutters and spits more than any car I got.
I am going to synchronize the 2 carbs, and would be really happy if someone know some great articles on this.
"old cars and bikes"
== System architect & developer
Old 07-10-2008, 11:58 AM
Wer bremst verliert
JohnJL's Avatar
Search, there are at least 10 2.7s owners out there who have shared their Weber setups.
Here are mine again;
2.7 high-compression, RS distributor curve
Weber 40IDA3C
BPR7 plugs
57 idles
180 airs
F28 emulsion
140 mains
Hope that helps
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-10-2008, 12:35 PM
teveo's Avatar
Thanks, I did a search and found some discussion, but I was perhaps looking more for an (external) article than a thread. I will do some googling as well..
I will take off the carbs and check the numbers in the weekend, I have to service the fanbelt ( thats what you get with the engine turned around in a 914 chassis ) and it will be convenient to do that now.
Old 07-10-2008, 01:14 PM
While you have the carbs off, check the idle jets and the passageways from the float bowl to the idle fuel needle jets.
Also carefully examine the idle jet o-rings, as well as the o-rings at the idle fuel needle screw.
If in doubt, that is if the o-rings are original to the carbs, replace them.
I was able to find the proper sizes at my local auto parts.
The three butterfly's are on a shaft. From the bottom examine the butterfly's with the idle stop screw fully backed off.
All three butterfly's must be closed equally.
If one or two are slightly open, compared to the others, adjusting the shaft coupler or even the individual disc's may need to be reset to get alll three discs equally closed.
Looking at the bottom of the carbs you'll notice a small hole in the side of the carb throat, a port actually.
This small port is where the idle fuel screw controls fuel flow at idle. This is the fuel supply to the engine at idle.
Now as you continue to look into the bottom, open the butterfly's slightly. You'll notice a small hole just above the butterfly as it opens. Continuing to open the butterfly's you'll notice two more holes exposed as the butterfly's open. A total of three.
These ports supply fuel from the float bowl through the idle jets to the engine.
The idle port below the butterflies and the three ports just above the butterflies are the fuel supply for the engine at rpm's up to 2500/3000.
Now look at the flange at the bottom of the carbs. You'll see a small square cut out with a hole in it. This is the air supply for the engine at idle. The air is controlled by the idle air correction screws. The screw on the side of the carb locked with a nut.
The air from this port at the bottom of the carb flows around the closed butterflies.
The idle is controlled by the idle fuel screw and the idle air screw.
It is best done with the butterflies fully closed.
Air will still get past the closed butterflies. Hold the carbs up to a light. Fully closed you will see light around the disc. This is as designed.
Adjust the idle with the butterflies fully closed. The idle fuel needle screw and the idle air correction needle screw will flow plenty of each to maintain a good idle.
Once the butterflies are opened at part throttle, the size of the idle jet comes into play.
An idle jet too small can spit through the carbs, too big and it'll spit out the exhaust.
Float height can confuse the situation. Get the float height right first.
Check the float height with the glass tube tool used to verify the float height while running.
If the floats aren't right, all the rest will be off.
Fuel pressure, 3.5 pounds. Check it with a gauge.
PMO supplies a regulator with a gauge. It is simple and trouble free.
Pat Braden wrote a good book about Webers. It's available from Pelican. Well worth the price.
There is more, keep reading and asking questions.
Good luck,
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 07-10-2008, 02:23 PM
sww914's Avatar
I've found that Webers routinely clog the idle jets more than once after an engine installation or any carb work. I wouldn't waste any time until after I have confirmed that the idle jets are clean.
Redline Weber has a good article on tuning Webers after they're properly jetted here- http://www.redlineweber.com/html/Tech/idf_adjustment_controls.htm
Have fun. I enjoy tuning Webers, I hope you will too.
Old 07-10-2008, 08:31 PM
BReyes's Avatar
What I have learned here may be beneficial to you. According to fellow Pelican,
"To set up the Webers, you should perform the following steps:
1)adjusted accelerator pump quantities
2)set float levels
3)equalized vacuum on each carb using idle air correction screws
4)balanced vacuum side-to-side @ idle and at 3000 RPM
5)adjusted idle mixture
6)set idle speed
Weber Set-up
Part I
STEP 1- Accelerator Pump Volume
Measure the accelerator pump volume at each of the 6 nozzles. Before starting the car, turn the key “on” and energize the fuel pump. Let the pump run a minute or so to fill up the float bowls. The air cleaners are off. Now, lower the vial down the throat of barrel No. 1 and park it directly under the nozzle. Have the assistant in the car depress the gas pedal all the way, nice and easy. Withdraw the vial, record the results on a piece of paper, and dump the contents of the vial. Repeat at each nozzle. (You may have to remove the velocity stacks for cylinders 2, 3 and 6 to gain proper access to the nozzles for those barrels.) Adjust the nut on the accelerator pump rod as necessary. Turning the adjuster nut out will increase the amount injected, and vica versa. You want .6 to .8cc (ml) (.75cc works great). Get them all even.
This procedure can also be done on the bench. Just fill the float bowl that has the brass valve in the bottom that feeds fuel to the accelerator pump. Then activate the pump and measure. The advantage of measuring at this stage, as opposed to when the carburetors are attached to the intake manifolds, is that if there is a blockage, it is easy to get at the check valves, nozzles, pumps, and float bowl valves and clean them out.
This procedure also provides a good opportunity to check that the throttle plates are opening all the way (vertical) with the gas pedal floored. If they are not, turn the plastic adjuster under the gas pedal in to give more travel, or out (less travel) if the throttle plates rotate beyond the vertical position.
STEP 2- Float Level Adjustment
Remove one of the two float bowl plugs on one of the carbs. There are two plugs per carb since there are two float bowls and two floats per carb. Careful- all the fuel in the float bowl will dump out so catch it with a little jar. Now insert the tool and tighten it to prevent leaking, since any leaking at the washer will give false readings. You need to focus on the upper two lines scribed on the vial portion of the tool. The lower two lines are for the Zenith carbs that some 911T's used (70-71). Have the assistant turn on the key to energize the pump but don't try to start the car. Now the float bowl will fill and you'll see gas fill the vial. After the vial is through filling, carefully examine where the meniscus is. You want it right between the top two lines. Turn off the key. Remove the needle valve plug, back out the needle valve and seat and add or subtract washers as necessary to raise or lower the fuel level, respectively. (ADD SHIMS= INCREASE FUEL LEVEL; REMOVE SHIMS= DECREASE FUEL LEVEL). Replace the needle valve and seat and the plug and have the assistant turn on the key. Note the fuel level. Continue to adjust until the meniscus is spot-on. The washers that come with the tool differ in thickness. After you do one, you will develop a sense for how many washers you need to raise/lower the fuel level. Then remove the other float bowl plug on the same carb and repeat the process. Keep at it until you've got them all perfect.
A couple of things- some books say to measure the fuel level with the car running. I've tried it that way and believe me, it's pretty hard to do since the engine is vibrating when it’s running. This vibration makes the fuel is slosh around in the vial and thus it becomes difficult to determine if the level is correct. This is exacerbated by the fact that the two lines scribed on the vial are near the very top of the vial. Second point-- the washers under the float bowl plugs are crush washers that are good for one shot. After you replace the plugs, if you re-use the washers, they are likely to leak. If you have some extra ones, use them. If you don't, don't overtighten the little bastards. Just snug them and move on. You can always order more from PMO and then go back and replace them at your convenience.
STEP 3- Initial Start-up Adjustments
Make the initial adjustments to the screws as per PMO and fire it up.
Initial adjustments (PMO) are as follows:
Idle air correction: 1/8 turn out*
idle screws: ½ turn in after touching throttle arm on each carb
idle mixture screws: 2 turns out
(*I suggest turning all the idle air correction screws in (gently!) until they hit their seats, and lock them down for the initial start up. You want a nice rich mixture for starters to avoid excessive popping which is really distracting, and then work from there.)
Here is where it gets tricky- while your assistant in the car keeps the motor running by judicious applications of throttle so that the engine warms, you have to diagnose in a grossly rough way, what is going on and what you need to do to smooth out the idle so that you can get the car running tolerably well enough to begin the real work of balance, synchronization, mixture adjustment and idle speed adjustment.
If the engine idles (regardless of speed) with the initial settings, do the following: if any barrel is spitting, slowly open the mixture screw- like 1/8 of a turn at a time. This should reduce the incidence of popping/spitting. Once the popping is reduced, quickly measure vacuum on each barrel with your STE. Are the barrels of each carb pulling roughly the same vacuum? If not, and vacuum is all over the place, determine which carb is pulling, on average, more vacuum than the other. Then open up the idle stop screw on the carb that pulls less vacuum, or turn in the idle stop screw on the carb that pulls more vacuum, or both, so as to get both sides roughly equal. Keep engine speed close to idle speed (900 rpm).
If the engine won’t idle, have the assistant hold it at a faster speed and adjust the mixture screws to avoid excessive popping. Once the engine runs smoothly, release the gas pedal and see if it idles. Check vacuum and make any adjustments to the idle stop screws that are necessary to get the car to run at idle. Once the car is warm (140 degrees or better) and holding an idle, it is ready for accurately setting balance, sync, mix and idle speed.
END PART I"
Bernard
Old 07-13-2008, 03:34 PM
BReyes's Avatar
"Weber Set-up
Part II
STEP 4- Vacuum Adjustment- (balance)
Disconnect the right and left carbs from the crossbar by undoing the short press rods on each carb. Use an 8-mm wrench to pop the ball cups free of the throttle arms. You don't want the linkage affecting this adjustment. Pick a carb. At 900 rpm, measure vacuum at each barrel and record results. Determine which barrel pulls the most vacuum (“reference barrel”). Lock down the jam nut on that barrel’s idle air correction screw. Now, carefully and slowly turn out the idle air correction screw on one of the two barrels that doesn't pull as much vacuum as the reference barrel. Get the vacuum exactly equal to the reference barrel. As you open the idle air screw to equalize vacuum, you are going to experience popping, since you are leaning out the mixture by introducing more air into that barrel's idle mixture. DON"T PANIC! Just open the mixture screw up a hair to compensate so that the popping doesn't distract you, or if it's just occasional popping, you can leave it alone for the moment. When vacuum is equal to the reference barrel, lock down the jam nut. Equalize vacuum in the remaining barrel the same way.
Now, you have all three barrels on the one carb pulling equal vacuum. Repeat the process for the other carb.
Step 5- Side-to-Side Balance @ Idle (synchronization)
Using the STE synchrometer, determine which side is pulling more vacuum. Turn the idle stop screws out or in a hair until both sides are pulling equal vacuum and you have 900 rpm idle. Turn the idle stop screws in to speed or out to slow, keeping each side balanced with the other. Now, the engine should be running at 900 rpm with each barrel pulling exactly equal vacuum. You are probably getting an occasional pop since your mixtures are all off.
Step 6- Side-to-Side Balance @ 3000 RPM (synchronization)
Reattach the press rods. Check the side-to-side balance at idle to make sure that the linkage isn't off at idle. If the press rods disturb the idle balance, adjust them so that they exert no preload on the carb throttles. Now you are ready for balance at 3000 rpm. Have the assistant hold the engine at 3000 rpm. Quickly run the STE over each barrel and record the results. Each barrel of each carb will match. But, your linkage could be off, causing the right carb to be out of sync with the left—that is, one carb may be pulling more vacuum than the other at 3000 rpm. If one carb is pulling more vacuum than the other @ 3000 rpm, lengthen or shorten the right/left press rods to compensate. When you get vacuum to balance at 3000 rpm, check that the linkage adjustment hasn’t screwed up idle balance. When vacuum balances at idle and at 3000 rpm, you are synchronized and ready for the "artful" part of this process, where it helps to have the ear of a musician.
Step 7- Mixture Adjustment
Speed the car to 1200 rpm using the hand throttle in the car to hold it there. (This is the BA method- put rock on gas pedal. PMO advises to disconnect the right press rod and speed the engine with the idle stop screws. I use the BA method.) Now start with barrel 1. Slowly turn the mixture screw in until you hear slight popping in the muffler- a little more and the idle speed drops. You may get an occasional BIG POP while doing this- this is normal. As soon as the idle speed drops, slowly turn out the screw until idle speed comes back up- this should take about 1/8 of a turn. You may hear that faint popping in the muffler at this point. If you do, turn the screw out a bit more until the popping disappears and the engine runs smoothly. (NOTE: Slow turns on the screw are warranted. Reaction to changes in the screw’s position is not immediate.) Now, note the position of the screw and slowly give it 1/2 a turn more. This is the initial setting. If it continues to pop or spit up before moving on to the next barrel, turn out the mixture screw an additional 1/8 turn. All should be well with that barrel for the moment. Proceed to barrel 2- same process- then 3, 4, 5 and 6. If it took ½ plus 1/8 of a turn to get barrel 1 to behave, then turn out the mixture adjustment screws for all of the other barrels the exact same amount.
After you run through them once, you will have some doubts as to whether you got the mixture on the first few barrels equal, since as you move through this process, you will begin to develop the "ear" and the "feel." Start over with barrel 1. Make sure that each screw is turned out the same amount from that point where the idle speed returns without faint exhaust popping after it has dropped as a result of turning it in. The point here is to get them all equal. Run through them as many times as it takes to smooth out all popping and spit ups and to get satisfied that you have them all open the same.
Insert from another source:
I'd like to add that small adjustments of the idle mixture screws can make a big difference in the air/fuel mixture at idle. And since the idle mixture on these carbs continues into part-throttle operation, some fuel economies can be found in this area. Most cruising, even at highway speeds, is done at part throttle. I used one of the popular DIY exhaust gas analyzers to fine tune the idle mixture. My idle mixture went from from 8% CO down to 4% in just a few fractions of a turn of each adjuster. Mileage went up too which shows you how far off my adjustments were.
Step 8- Idle Speed Adjustment
Release the hand throttle and let the engine return to idle speed. If idle speed is off, disconnect the right and left press rods. Adjust the idle speed to 900 rpm with the idle stop screws. Make sure that side-to-side vacuum remains equal. The engine should be running smooth- no popping and holding a nice idle. Reconnect the press rods and check balance at idle and at 3000 rpm again just to be sure!
Step 9- Test Drive
Take the car for a test ride. Is there any surging between 2000 and 3000 rpm? Is it popping on deceleration? Is it transitioning seamlessly between idle and main circuits? That is, no flat spots, right?
Return to home base. Make any final adjustments that you feel are necessary to the mixture screws. In other words, if it popped occasionally or surged, turn all mixture screws out an extra 1/8. Repeat test ride. Make any further adjustments that are necessary.
If the mixture screws are turned out more than 3 ½ turns from full in, the idle jets are too small. If the engine stumbles on acceleration or is slow to return to idle, the idle jets are too small.
End Part II"
Hope this helps you too. Thanks goes to Original poster
Bernard
Old 07-13-2008, 03:35 PM
Now just a minute....your photo reveals the use of a cabinet door for an engine cradle build. You'll be hearing from my patent attorney in the very near future......can't have everyone in the bloody country doing this, eh.
Royalties would make things right.
I don't load the box between the jack & cradle till after the engine is under the car & up in the air a bit. ...
JPIII
Early Boxster
Old 07-13-2008, 05:16 PM
JP I think he bought the bumblee from rob who had shop in CA work on the carbs and misc.
Old 07-13-2008, 07:44 PM
Humm......small world. That would be a picture taken few years ago by Jim Chambers then. I'm becoming unconfused.....
JPIII
Early Boxster
Old 07-14-2008, 04:02 AM
Wer bremst verliert
JohnJL's Avatar
BReyes and 2.7 got it right.
If you havent sync'd them you havent even started. Do the procedure from the beginning, preferably with an LM1 tailpipe-setup on hand before proceeding.
Old 07-14-2008, 04:28 AM
teveo's Avatar
Yes, that is correct, you need show me the international patent before we speak royalties here..
Old 07-14-2008, 04:53 AM
teveo's Avatar
.. yes, btw I must thank our hard core carb experts, tons of info here! I will get back with setting when I disassemble.
The carb job is on hold this week as I am installing a new top on my 61 XKE, my fingers are worn out... wooden tacking strips, glue, screws, washers all in a nice mixture.
The bumblebee is being prepared for track days/autox in Norway, tune the engine and fix some minor rust and it should be ready for actions.
Old 07-14-2008, 05:01 AM
