super9064's Avatar
71T to E Cam timing specs
My 71T was rebuilt by the PO with E pistons and cylinders and Webber carbs, I have obtained E cams and an E distributor and my mechanic will soon be installing them, he asked me if there was a trick set up for the cam timing that I knew of or just go with the stock set up. What would be the best cam timing? Thanks.
Old 07-16-2008, 02:47 PM
Home of the Whopper
3 - 3.3 mm
3.15 desired
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 07-16-2008, 03:18 PM
