-   -   Which head studs to use? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/419987-head-studs-use.html)
SigmundF 07-15-2008 05:29 AM
I am rebuilding a 2.0L (aluminum case) to a 2.5 SS. Could I use the original head studs, if not, what type should I use?
Eagledriver 07-15-2008 09:13 AM
There are numerous threads on this. My opinion is to use the original steel studs with that combination.
-Andy
Steve@Rennsport 07-15-2008 02:03 PM
Use your stock steel ones with confidence,....:) :)
J P Stein 07-15-2008 05:04 PM
Your post suggests (short stroke) 90mm cylinders.
If so, Dilavar.....the coated, full thread jobbies.
On the other hand, I never disagree with the good Mr. Weiner & I'll probably get a quick education.:D
SigmundF 07-16-2008 12:54 AM
Thank's for the replays, I have full confidence in Steve, so I use the original ones....
