2002 911 ims bearing
hi .im in the middle of replacing the ims bearing on my 2002 911 . how do you remove the bearing if only the outer race is left in the shaft...all the little bearing flew out of the center ..and the out race is in there..there is nothing grab on to pull it .can anybody help thanks ..
Old 08-29-2013, 05:52 PM
otto_kretschmer's Avatar
you may want to post this in the 996/997 forum
Porsche 996/997 Forum - Pelican Parts Technical BBS
but if I understand your question, try a slide hammer
Slide Hammer - Great Deals on Slide Hammers at Harbor Freight
Old 08-29-2013, 06:19 PM
ok,
I don't have a boxster or a 996
so it looks like there is not a lip of some kind for the slide hammer to hook onto
if that is the case, then you will either have to buy, rent, borrow the right tool, or make something that you can use a slide hammer or some other kind of extracter
http://www.youtube.com/watch?v=hAxj6FKMzvM
Old 08-29-2013, 06:29 PM
there is no lip .. I was thinking trying to cutting it then use slide hammer is that a good idea? will it hurt the other side of the shaft is I use a slide hammer?
Old 08-30-2013, 11:29 AM
I also notice that the shaft is not center .." It slightly shift to the driver side" will it go back center if I loose the timing tensioner.
Old 08-30-2013, 02:52 PM
if you're really careful with a dremel, maybe you can cut a slot for a slide hammer
there has to be someone on Pelican who has done this job before, so I'd keep looking for that person here or maybe on Rennlist
Old 08-30-2013, 03:23 PM
