teveo's Avatar
Locktite 573 or 574 for camtower to heads?
Hi, In the bentley or porsche orig workshop they refer to using the 573 when mating heads and camtowers. The specs are almost identically on these two products.
I cannot get the 573 locally, but I do get the 574. Any problems sealing with the 574 instead of the 573 on the heads/camtower?
The engine these go on is a 2.7 I took out of my 77S, I bought another (SC) engine for that car and this late 7R engine is currently going in pieces becoming a 2.7/2.8 RS spec engine.
"old cars and bikes"
== System architect & developer
Old 02-04-2009, 03:54 AM
abit off center
cgarr's Avatar
The 574 is faster setting (only an hour) the 573 is slower setting (6 hours) I always use the 574, the orange stuff.
Spec sheet says:"574 Fast-strengthening version of 573. Begins to harden in 1 hour; reaches full strength in 12 hours. Comes in a paste"
______________________
Craig
G2Performance
Old 02-04-2009, 04:53 AM
Porsche's Love-em Live-em
This is one area I would go for the best money can buy.
That be "Dow Corning 730" @ $100 a tube!
Sand & clean mating surfaces very carefully as well for best oil tight seal.
Old 02-04-2009, 11:08 PM
BoxxerSix's Avatar
574 has never done me wrong when applied properly, to properly prepared surfaces. The key is just being prepared so you don't have to backtrack after sealant has been applied.
Adam Hennessy
Old 02-04-2009, 11:22 PM
Jeff Alton's Avatar
Here we go again.....
I have used Loctite 574 and threebond (yamabond) 1104 and dow 730 all with good results. I prefer either the 110 or 730, just me preference though. Thankfully I have never paid anywhere near 100/tube for 730.......
Cheers
www.turn3autosport.com
Old 02-04-2009, 11:34 PM
OldTee's Avatar
Bring it in from the cold before you appy it.
Old Tee
all 911s sold
Old 02-05-2009, 08:28 AM
teveo's Avatar
Thanks everyone, will use the 574 and wont be lazy...
Old 02-05-2009, 08:29 AM
Aircraft Permatex in the brush on bottle, it was good in 1980 and still good today.
Stays pliable and out of the oil system
Bruce
Old 02-05-2009, 03:55 PM
abit off center
cgarr's Avatar
Bruce
But only if you use a #50 silk thread.
Craig
G2Performance
Old 02-05-2009, 05:29 PM
T77911S's Avatar
what is the best way to apply to the cam towers
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-04-2009, 07:03 AM
abit off center
cgarr's Avatar
I think I used a small acid brush, but I have seen some use a small foam roller which seems to work very well to apply an even thin coat of the 573
Craig
G2Performance
Old 03-04-2009, 09:31 AM
mca mca is offline
mca's Avatar
I used some cheapo foam brushes from Lowes. They have a tapered end for tight spaces. Worked like a charm - brush didn't break apart or anything.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 03-04-2009, 10:46 AM
