-   -   Camtiming (http://forums.pelicanparts.com/911-engine-rebuilding-forum/420908-camtiming.html)
linnefell 07-20-2008 01:14 AM
Camtiming
Hi I wounder if any one can recommend how I should set the timing
Have a 930 engine with SC cam. original should set 1mm. but with this cam should i go for 1,4mm. or more??
the engine is now 3.2 liter and have JE pistons and ported heads etc.
big turbo.
Lennart
MBEngineering 07-20-2008 02:41 AM
HI Lennart
I would set the cam timing at 1.4-1.7 for the SC cams , but if you engine spec is as good as you describe, i would have gone for the group "B" cam.
regards mike
linnefell 07-20-2008 05:27 AM
yes the engine is wery nicehttp://forums.pelicanparts.com/uploa...1216556835.jpg
