3.6 to 3.6x51?
Has anyone done this and what is involved? I have a 3.6 on the way for the Boxster and while I am there I want to add a few things.
I need: Lightweight flywheel 3.6 to 3.6X51 conversion 7.8 DME TIA JP |
JP,
Its not too bad,...:) The lightweight flywheel is available for these cars and its a very well made aftermarket item. We've installed several of them. :) The 3.6 X-51 engine kit is a dealer-only proposition and not cheap at $ 8500. You will need a 3.6 DBW 7.8 ECU (new or used) that can be re-flashed to work with the X-51. You will need to get your Immobilizer codes installed in the replacement ECU by a local dealer to enable it to start. |
Thanks for the info but what I have coming in is a 3.6 for my 00 Boxster S. I will be adding my Imagine Auto Super Charger to it that is already on the car. What I was looking for was the details on making the 3.6 into a x-51 motor. I know it has cams, intake and some valve work and none of these are out of the question while the motor is out. I just want to do this once. I already have a line on the harness but still need the: 7.8DME LWFlywheel and source for the cams or better sport set if possible. |
The DME would be a dealer item unless you locate a used one. Trouble is, those are usually sold with the engine when removed from a wrecked car since the Immobilizer codes are matched. You can contact me directly about the LWF. |
| All times are GMT -8. The time now is 04:40 AM. |
