-   -   this case requies "oil bypass" or not? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/423567-case-requies-oil-bypass-not.html)
dan67 08-05-2008 03:01 AM
this case requies "oil bypass" or not? 2.7MAG http://forums.pelicanparts.com/uploa...1217930492.jpg
cgarr 08-05-2008 05:04 AM
I don't see the return hole plugged, so I would say yes.
304065 08-05-2008 06:30 AM
Dan, as you can see the return hole is still there (good eye Craig!). So this case will need the bypass mod.
That said, you should have this case inspected FIRST before performing any machine work, it's entirely possible that it is unusable due to the advanced state of corrosion visible. I would have it checked by a competent machine shop before starting work.
http://forums.pelicanparts.com/uploa...1217943003.jpg
