-   -   Funny scraping sound (http://forums.pelicanparts.com/911-engine-rebuilding-forum/423586-funny-scraping-sound.html)
Inter911 08-05-2008 07:06 AM
There's a funny scraping sound coming from the engine in my car. Engine is an old 2.4 T and the noise only occurs, if at all, when the engine is warm and when you let off the throttle and come to a stop. Seconds after coming to a stop you hear a high pitched, metal on metal scaping sound. It'll happen for a few seconds or so then go away. It may happen again or not. Its very noticable such that someone beside the car at a stop would hear it.
It almost sounds like what you'd hear with a household fan going bad. Did not hear this noise until I installed a remote oil cooler up front though.
Brian
waynesco1 08-05-2008 10:54 PM
Alternator bearing ? starter hitting ring gear ?
Wayne 962 08-06-2008 12:21 AM
Doesn't really sound like an engine problem, if it's related to the speed of the car...
-Wayne
MBEngineering 08-06-2008 02:41 AM
HI Brian
back of the rear wheel/tyre rubbing on the oil pipes??
regards mike
911 tweaks 08-06-2008 04:59 AM
a wheels brake pads shot and they and or caliper rubbing on brake rotor ?
does any clutch activation create or stop noise ?
just another guess... good luck
Inter911 08-06-2008 06:09 AM
I doubt if its related to the running gear because the noise happens at a complete stop. That's why to me it sounds like engine related.
The alternator bearing sounds like a possibility. Its out of the engine now...is there some way to diagnose that?
Because I installed the remote cooler prior to the noise I am worried that I might have an oil problem that is ruining something inside the engine. The oil cooler is a Mazda RX7 cooler, cleaned to be sure there was no crud in it. The lines are AN12 stainless and I'm using a Mocal thermostat.
