Which PMOs !!!
I have a -79 SC engine large ports, SS 3.2 syl, JE 9.8 pistons. 964 cams, ssi ex. blue printed, and would like to have a pair of PMOs on this engine.
The car is mostly driven on common roads. Should I go for 40s or 46s ?? |
46's would be appropriate w/38mm venturis.
Will this give some more HP ??
More HP than CIS???? OMG, yes. :) |
Thank you Steve !!!!
My race group has found about a 7HP peak improvement with 46mm carbs vs 40mm carbs. This only occurs above about 6000 RPM.
-Andy |
| All times are GMT -8. The time now is 06:07 PM. |
