Which way do the rod numbers face?
I am in the process of assembling a 1980 911 3.0 lts. Which way do the numbers on the connecting rods face. Up or down? When I took it apart the numbers were facing up on the right bank and down on the left. The manual I puchased says to face them all to the exhaust side. Which way is correct. Thanks for you time to help me out.
Mike. |
It doesn't matter. You only have to make sure the numbers match and are on the same side on the rod as on the cap. I put them all one way just to be consistant.
-Andy |
Thanks Andy!
| All times are GMT -8. The time now is 02:36 PM. |
