Case Bearing Saddle Alignment
Dear Pelcanites
In order to determine if a line bore is required the method I'm about to attempt is placing a straight edge on all the case main bearing saddles and measure the gap between the saddle and the straight edge with a feeler guage. Is this an accurate method and what is the tolerance I should expect?
TIA
Bill
90C2
Old 08-22-2008, 04:51 AM
