Cam Characteristics
Can anyone share information or point me somewhere that gives info on the torque and HP levels of the varying 911 cams?
Specifically I'm looking for comparisons between S, mod S, DC 42, DC 44 Where peak hp and torque is made through the rev range. Thanks Cam (no pun intended :D ) |
Check this post out. It might help.95mm & higher compression post
It really depends on the engine they are going in. S cams typically have a high, narrow powerband (5000 to 7000+ rpm in a 2.0 litre for example). In the same engine the DC40 (mod-s) will run from 4000 to 7000+ rpm, about 1000 rpm wider. It will also have more peak torque and HP. The DC43 and DC44 cams are normally on a wide lobe center vs. the S and DC40 (mod-s). I usually grind these for bigger engines, 3.0-3.5 litres with some type of aftermarket EFI. I have made a few sets of 102 lobe center DC43 cams. These would have a similar powerband vs the normal DC40 with some added valve lift. I would use the DC43-102 over the standard DC40 if the customer had a ported set of heads with better high lift airflow. |
Thanks Guys
John thats a big help. I'm heading towards something that just a little bit more than a mod-s for a 2.3 twin plug engine. Happy to do the extra head work if that helps to achieve around the goal of 200 hp. Can I ask where peak HP and torque are achieved in the DC43-102 cams? Many thanks. |
Depends on throttle size, compression, how big the ports are etc.
How high are you going to turn it? You are probably better off with a DC60, or maybe a higher lift DC62 on 102 centers. This is the type of info I look at to decide a camshaft, http://www.drcamshafts.com/caminfo.htm |
Hmmm...I am using a set of DC44s on 102 centers on basically the same motor: a hot 2.3L. What is the general difference between the DC62s and DC44s other than the extra 12 hundredths on the intake side? I see the durations are different; to what effect?
I'll have it running no sooner than early winter. |
Kenik
Stranger things may happen! John I appreciate your input. |
| All times are GMT -8. The time now is 11:31 AM. |
