-   -   Soda Blasting (http://forums.pelicanparts.com/911-engine-rebuilding-forum/425602-soda-blasting.html)
Porshaah 08-17-2008 12:05 PM
Soda Blasting
Fellow Pelicanites
Is it OK to hit the mating surfaces (i.e. head/cylinder, cylinder/case, case/case) while cleaning (i.e. carbon/oil stains, old sealing compound) with soda at 100psi? Will it damage the sealing surface?
1990 3.6L
TIA
Bill
90C2
dcriss 08-17-2008 12:23 PM
Hi Bill,
I am running my soda blast pod at 120psi and I have noticed no problems with the mating surfaces. The soda is very good for such conditions.
That being said, it would be interesting to hear some additional thoughts (since I have only had my blast pod for 3 months)
Regards,
Steve@Rennsport 08-17-2008 01:34 PM
Originally Posted by Porshaah (Post 4124792)
Fellow Pelicanites
1990 3.6L
TIA
Bill
90C2
Bill,
Use that stuff at 100-120 psi with no worries,..:)
Thats the very best way to clean aluminum engine parts.
Porshaah 08-17-2008 01:47 PM
So the dullness I see after I hit a shiny aluminum surface is not pitting the surface?
1st time 911 rebuild
TIA
Bill
90C2
