location of intermediate shaft size stamp on case
hi all.
I'm trying to figure the sizing on my case for a new shaft but i can't find the case stamp. the factory manual says "beneath the alternator mount on left side of case". Can anyone be more specific or show a picture please? thanks. |
HI whackit
the code is hear on the case http://forums.pelicanparts.com/uploa...1219050065.jpg you could have a "0" or a "1" stamped there as to what was fitted from new. regards mike |
hmmm. nothing on my case.
Do you have the pulley off? Mine is under the the pulley but in the same area.
Here's the only marking I found in the area described. Would you consider that a 1?
http://forums.pelicanparts.com/uploa...1219099749.jpg |
anyone?
Thats not a 1, looks like you are going to have to check it when its apart.
When I needed a new gear on my intermediate shaft I found that only one size was available. It's been a couple of years but it seemed to me that unless you have 1's on both the crank gear and the case you can use a Zero gear. The rule is specified in the factory manual.
-Andy |
actually if you do have 1's on both the crank and case then you CAN use a 0 gear. Here's the table:
http://forums.pelicanparts.com/uploa...1219421890.jpg |
| All times are GMT -8. The time now is 03:39 PM. |
