Two Rivers's Avatar
66mm crank,90mm pistons Q
If I put a 66mm crank in a 2.7L case with 90mm pistons it should be a 2.5L. Will this work? Going from a 2.2L to a 2.5L will it make a difference that will be noticed. Thinking a E or L cam and 40 webers. Have a 2.2L with T cams and 40 webers now in a 70 targa.
Old 07-06-2010, 07:03 AM
356RS's Avatar
Yes it will work. This is a very popular engine build with a rewarding outcome when done right. What will this engine project be used for? Street or track & street?
Mark Jung
Bend, OR
MFI Werks.com
Old 07-06-2010, 07:38 AM
BURN-BROS's Avatar
It will work, but it will only be a function of a displacement increase. If I were building an E for the street I would build a 2.7, 2.8, or 2.9.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-06-2010, 07:53 AM
Two Rivers's Avatar
Street only, restoring the 70 targa stock just looking for a little more power. I don't see the L cam mentioned much. When cruising 90 to 110 the 2.2T seems out of breath.
Old 07-07-2010, 07:01 AM
3 restos WIP = psycho
kenikh's Avatar
Great motor, depending on pistons and cams. RS 90mm Mahle compression is too low on a 66m crank, so you need pistons from JE. The 2.2T is out of breath due to cams, as a 2.2E or S are great motors. E & L cams are theame IIRC. L might be Solex (also nice), but can't recall.
I'd be quite happy with a 9.5:1 CR 2.5L w/ Solex cams and 36mm port heads. This would result in a wicked torquey near-200HP motor with over 7000 RPM power.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-07-2010, 07:40 AM
356RS's Avatar
Do you have the 70.4mm crank from the 2.7 case? Or is the 66mm crank all you have.
Sense this will be street only and if you have a 70.4mm crank, Aaron's suggestion for a 2.7 would work great especially with the E cams you already have.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-07-2010, 07:52 AM
Two Rivers's Avatar
Thanks I always thought a short stroke big bore engine would be a nice package.
Old 07-07-2010, 10:19 AM
