-   -   Orientation of Mahle 98P11 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/427047-orientation-mahle-98p11.html)
renders 08-25-2008 08:16 PM
Are there any installation instructions available for Mahle 98P11. What is the orientation of the piston in the cylinder? I can't find anything about this. Here is my set of pistons.
http://forums.pelicanparts.com/uploa...1219720491.jpg
Is the following installation correct (the large flat area facing to the right) or do I have to turn the piston 180 degrees?
http://forums.pelicanparts.com/uploa...1219720546.jpg
Fast Corners 08-26-2008 09:35 AM
I'm not sure about your particular pistons but some Mahles have an arrow pointing to the top of the piston. Can you determine which valve pocket is the larger of the two? The larger pocket goes with the larger (Intake) valve.
renders 08-26-2008 09:54 AM
That is the confusing part. They are both of the same size 8) However the pistons were marked with an "E" at one of the pockets so I am wondering if that is the orientation towards the Exit valve? I hate guess work but it would make sense.
dpitman9 07-06-2010 09:15 AM
How did this orientation question end up? I am facing the same issue.
Flat6pac 07-06-2010 08:09 PM
The high side of the flat area will be away from the plug.
Bruce
renders 07-07-2010 07:04 AM
Check my complete rebuild thread with lots of pictures. You can see how it should look. I just goofed on the cam timing. Engine is back in the car again and should be running soon I hope.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/545476-911-3-2-3-4-conversion-engine-not-running.html
