need advice on a few parts...
I am ordering all of the parts (bearings, gaskets, etc...) in order to rebuild my 930 motor. Now my first question is about obtaining new oil galley plugs- I want to yank all of the oil galley plugs and get the case 100% clean before I re-assemble. If anyone has some part numbers I would be sooo happy and any info about them as well.
Now my next question is about the solid cam chain tensioners I am going to run. Now I have never adjusted solid tensioners and need advice on any spec that I can use to tighten/adjust them. I know almost everyone is going to say that I shouldn't run the solids, but it is from my own personal preference. Any advice on these matters would be greatly appreciated. |
Somebody?
HI 930gt-40r
some off the plugs are not available, so hear is what I have , main oil gallery on top of the engine, R/H side; 911 101 185 00 22.00 X 9, small oil gallery over the nose bearing No' 9; 911 101 182 00 13.00 X 8.5, OR the OVER SIZE plug; 911 101 182 01 14.00 X 8.5, small plug on the top of the main oil gallery for the intergear bearing feed; 911 101 186 00 7.5 X 8. !!!please check the sizes on your engine before removal!!!! the cam box plugs for the oil spray bar is 901 105 379 00. regards mike |
HI
forgot about your tensioners, as you have a TURBO, I would go with STD or CARRERA pressure tensioners, as the L/H one is behind the turbo and not easy to get to, for checking/adjustment on the solid ones, but if you must , how old are the chains?? as to how tight you adjust! regards mike |
Mike, you are a saint, thank you.
The chains in my motor are about 6k miles old. As far as the turbo goes, I know it is going to suck trying to get in there, but after the carnage that the pressure fed tensioners caused, I am not hot to use them. I guess I could use the origonal standard turbo tensioners with collars, but I am reluctant because what tells you when those go bad with them riding the "bump stops"? Thank you for your advice. |
| All times are GMT -8. The time now is 01:14 AM. |
