Cylinder Base Gaskets
OK, just checked with Walt and found out they did cut my heads down .25 so I need to add another .25 cylinder base gasket. Can I reuse the old ones with the new set to make the .5 mm? I plan on checking the deck height using Walt's method listed in Wayne's book to see if it's in spec. If the deck height is in spec am I okay to proceed?
Would not re-use the old ones, either stack two new ones, or better yet, Andial has different thickness base gaskets available, I think I may have gotten these from EBS before.
| All times are GMT -8. The time now is 05:49 PM. |
