-   -   Look What I Found Inside Cylinder #6 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/429911-look-what-i-found-inside-cylinder-6-a.html)
lucittm 09-11-2008 01:22 PM
Based on low compression and a bad leak down test on #5 and #6 , I pulled the engine and tore into the right side.
This is what I found:
http://forums.pelicanparts.com/uploa...1221164038.jpg
The heads were dirty but looked OK otherwise:
http://forums.pelicanparts.com/uploa...1221164079.jpg
The good news is that the Mahle cylinders look good, the bad news is the top and oil control rings were broken:
http://forums.pelicanparts.com/uploa...1221164162.jpg
None of the Dilavar studs were broken or pulled and I was able to extract all the intake and exhaust studs on the three heads.
Now to send the heads off to be cleaned and tested.
Mark
relayswitcher 09-11-2008 01:46 PM
What kind of noise where you hearing obviously on the right side? I"m about to do a 4-5-6 investigation, but my noise was a rolling rattle. The bottom end sounds relatively smooth even on the revving up to a medium speed. So I'm thinking it's top end. I'm going to post my tear down "progress as I go" a little later today. Good luck to you on your dilemma.
Relayswitcher / Josh
lucittm 09-11-2008 03:23 PM
There was no noise. The engine ran strong with a slight miss when the plug would foul. I was using about a quart of oil with each fill up.
Mark
