correct measurement for 2.7 rod journals
I have a 2006 wayne book, and it shows the rod journals as 56.971-56.990
I have 2 cranks with matching numbers and much smaller journals. is the book in error? what is the correct standard rod journal for a 2.4 - 2.7 (70.4mm) crank? thanks in advance brant |
New Max diam - 51.990 mm
New Min diam - 51.971 mm wear limit - 51.960 mm 1st undersize is 0.25 mm less than these numbers. |
thank you Tom
now mine look much better I'll correct my copy of the wayne manual brant |
| All times are GMT -8. The time now is 01:10 AM. |
