What kind of washer under timing chain case nut?
Anyone know what kind of washer goes under the nut in the timing chain housing of a mag case? Aluminum, Spring, Steel?
If you are talking about the 15 mm nut and washer inside the chain housing area that helps hold the case halves together...It's a steel flat washer.
| All times are GMT -8. The time now is 08:49 AM. |
